this is a typical example of something i didn’t want to do because i was just downloading alphas and then it appeared lol.
Sketchfab : Hibou - Nomad Sculpt - Download Free 3D model by costorella [9d1b6f4] - Sketchfab
What a fun design!
Thank you !
WAW! I wish I can reach you level
Thank you. But its an easy doodle for everyone
But can’t make such display, ee what’s that’s call again? Rendering? Render? I mean something that make 3D sculpt looks good is my weakness I believe.
there is no real rendering with nomad sculpt it is
earlier a clean export of the working window is almost “wysiwig” (what you see is what you get) so here in nomad it is easy not to play with a boring quantity to get a final image enough good just with the post process
The render in Nomad is indeed a more or less a screenshot, with the exception that the resolution is forced to x2.0.
You can change the resolution in the Settings menu (by default it should be x1.25).
It’s best to leave it at x1.25 most of the time for better performance and longer battery usage.
Sketchfab of this model for test : https://skfb.ly/6Zn7Y
