Would it be possible to have the option of masking different areas of the same object so that you don’t have to clear and redo masking for various stages of sculpting?
A good example: https://youtu.be/UD4aNcPzpk0
Various parts of the object are grouped. Then the whole object can be sculpted on OR you can select a filter to restrict to a masked group.
I often run into instances where I have to unmask areas, make changes, then remask. Being able to group masked areas would make it much faster and less repetitive.
