Mask‑Front option produces effect on the back face
The mask feature works really well. However, I’ve run into an issue. When using the Sel Mask tool with the Front option selected, my brush selection creates a mask on the back face instead.
I have tried saving and restarting the app, as well as flipping normals, but none of these steps fixed the problem.
Device: iPad Air 5
App Version: 2.8 (latest)
*This post is translated with translation software, please excuse any inaccuracies.
I think it will be fixed for next update.
(you can always test at nomad - WebAssembly to see if it works).
Thanks for your help! I found the root cause. I used Flip object (X‑axis) in the Symmetry menu after joint‑splitting one side to reconstruct the model. After flipping it once more, masks work properly.
I’ve tested this issue on the WebAssembly build of Nomad, and the bug still exists.Is this intended behaviour or a bug?
Trigger conditions:
On the Nomad WebAssembly build, click Flip object (X‑axis) under the Symmetry menu.
Drawing tools and the mask‑font tool work correctly. This issue only occurs with sel mask‑front.
Indeed, will fix it.
