Mask by topology (like zbrush)
Hello, I need to mask along the topology of an animation mesh (human).
In ZBrush I would enable a transpose line, then while holding down control (mask) I would drag LMB along the surface of the mesh. The mask begins and follows where I am dragging according to the edge loops. For instance the mid-thigh: If I drag down the mask appears on everything above my cursor and as I drag down the mask increases in size following the topology. Example 2: The mouth and lips. If I drag up over the lips the mask would follow my curse and as I cross the lip separation I stop, the result being the bottom lip completely masked and allows me to then sculpt on the top lip and protect the bottom lip.
I would love this in Nomad, thank you.
This is a much sought after feature. It really is invaluable when it comes to masking out areas like eyes, mouth etc.
Hate to bump this but surely i cant be the only one that would kill for this feature. Would even pay for it like the quad topology.
It can be really cumbersome without this feature.
I personally use the lock radius funktion to mask overlapping parts.
It‘s not the same but helps…
