It’s not completed yet…
The dragon is an Alpha stamp? That, or you are an extremely patient Crease brush user.
I used the Alpha from z-brush repository… But I had to crease some edge get desired results… Finished artwork will look better than this… ,
Here’s the final render of the machete from Nomad sculpt… Post processing was also added on android…
What is primitive object u used to make an objek blade.
I used box scaled it flat for the blade and another box but the handle , then I voxel merged them together…
Are you draw again?
With image edit?
My result not look so fantastic like you are …
Hehe
Hope u dont mind i reuse the idea.
Cuz i think is so cool.
It’s great man… ür design looks clean and minimal…
I rendered my piece on Nomad before the post processing was added to Nomad…
At that time I used to render like dis→
I would render 2 or more renders using a pbr and other ones using matcaps…
After that I composed them inside infinite painter ( as I have a android device, you may use procreate for this)
Now my work flow has changed a bit, but I still render out multiple passes for the final image…
