Is there a tool to lock some meshes?
Doing a lot of tweaking for one particular object. Don’t want to hide everything else but also don’t want to accidentally change it.
No lock or freeze unfortunately.
Something really missing.
If it’s just one object use “solo”
To avoid editing things by mistake do following:
- select one object
- press smooth and select the other objects you want to edit
- tap on solo
- Now tap on the object you want to edit first to deselect the others and start editing. You can even use the lock function to lock your selection now.
It only works with smooth select function.
You could use the lock button. It makes it so you can’t select anything else unless you go through the objects menu.
How do I fix the lock scene In nomad
