I’m wondering is there a way to repeat a stroke? example; I have used the crease brush and like the stroke I did and just want to use the exact stroke again to emphasis it.
If this has been answered before please remove.
Thanks!
Thanks!
Not possible for now.
You can just create a shape in procreate or photoshop whatever you draw digitally with and use it with any tool that allows you to change the alpha. It has to be white on a black background.
Or you can add a new layer, make the stroke, duplicate layer (few times if needed) and then merge/apply them to the object.
I’ll give that a try Alex, thanks for the suggestion.
