I think some of this is already planned or has already been discussed, but I can’t seem to find it.
- Tool options for insertion point snapping: right now it snaps the center point of the inserted mesh to wherever the insert point collided with another mesh (if it did). It might be nice to be able to have the edge of the inserted mesh placed at the insertion point instead (like you fired the mesh at it and it stuck where it hit). In this case, the new object’s pivot should probably be placed at the insertion point to start.
- Normal stroke options for mesh insertion (dot/stamp/spacing/etc) to allow for drawing a series of meshes along a surface or placing and adjusting the size/rotation by dragging. Though, it seems like this might need to insert lower-resolution meshes by default, as I could see polycounts going too high too fast. Options for alignment of the inserted mesh (especially relative to the normal of the surface at the insertion point) would be useful too (this would probably need a new UI element, though)
- Auto-voxel-merging meshes (or an option to do so, at least) added in a single stroke with the previous option would be nice.
Anyway, just dreaming a little.
