In nomad sculpt, we can only use imm brush with sphere, cone, box, etc. Can you add a feature that allows us to add insert brush’s mesh that we sculpt?
There is a clone and instance option in the left bar, above the primitives.
I like to use it like imm brush. Would that be the solution for me?
I don’t know and don’t understand your question.
Just test it and you’ll see, the buttons are there.
Sorry, I should have write it more clearly.
When I make this mesh to instance and insert to other mesh(sphere) with instance it inserts the other mesh(sphere).
Do not select the sphere… you just click on it.
Also do not instance manually, the whole point is that it is going to instance the selection.
- select your ovale thing
- drag on the sphere (it will parented to it)
Thanks it worked. But the ovale doesn’t appear on the surface. It just passes the sphere.
Hmm not sure I get it.
I was wondering inserting like this picture but I got it by moving ovale’s gizmo. And since I’m accustomed to zbrush, could you make insert’s first option to be scaled like the other original object’s insert works? Also, thanks for replying fast.
