I have noticed that when using the GIZMO, it is no longer possible to input negative values; for instance, if I wish to set a displacement on the X-axis to -4.5, Nomad does not allow it. I can only move manually using the arrows, but direct numerical input is no longer permitted.
It only doesn’t allow me to enter negative values, both on a smartphone and on a tablet, and even if I connect a Bluetooth keyboard, the “-” key is not inserted.
Are there any updates regarding a fix for the issue that prevents entering negative values via both the virtual and physical keyboards? I urgently need this resolution for certain projects I am currently working on.
