Found a bug
I’m using windows 11 pro and Nomad 2.9.7. I don’t know how to call this bug, but the remash disappears and few other things happen.
Do you replicate the issue?
I think the issue is not necessarily with voxel or operation but with something that happened earlier that broke the app state. I don’t know what though.
Yes, I can reproduce the error every time. It happens when I use decimate or quadremesher. I found a way around this is to rename the object after remeshing and then perform operation or just touch the object with the smooth brush. I also used lock after remeshing and then performing operation, it will work.
But just on this object?
If it only happens on this particular object, then you could send me the project.
If I can replicate the bug I can fix it, otherwise I can’t.
The 2.9.8 doesn’t have that problem anymore. It’s all good.
