Flattening only the bottom vertices using Move
I’m using Nomad Sculpt 2.8 on iPad.
when I try to flatten only the bottom vertices using Move, the whole mesh is affected, unlike in the tutorial.
Watching the entire 12-minute video is a lot of work, so please indicate the timestamp where the relevant part begins.
Regarding the issue at the 2-minute-15-second mark of the video, if you reduce the brush size, the unwanted mesh
of the object should remain unchanged.
Sorry
Sorry about that, and thank you for your help! I was able to fix it by reducing the brush size.
