Hi I would like to request for the ‘DynTopo’ toggle & shortcut menu to be permanently open on the screen when activated and pinned, just like the ‘Stroke Painting’ shortcut tab.
Currently, dragging the DynTopo menu out from the shortcut or toggle buttons, and then pinning it on the screen, keeps it on the screen while I’m sculpting with DynTopo. I use it all the time now ever since it was implemented, thanks for the feature.
However, I noticed that the DynTopo toggle menu (DT) and Dyntopo shortcut menu (DS) behave differently. When I switch to a tool like ‘Trim Tool’, the DT window closes. DS remains open. When I switch back to a tool with DynTopo activated, I have to click on the toggle to access the DT window again. So I have been using DS to keep the DynTopo menu permanent on my screen.
Another thing is that after a mesh has DynTopo activated and then switched off, both DT & DS tabs will minimise. Sometimes I toggle DynTopo often and the min/max window behaviour can be distracting. Is it possible for it to not minimise, like the Stroke painting toggle menu? If others prefer the minimised window then it would be nice to have a choice to toggle collapse the window.
I wasn’t planning on sending this request but I was afraid that the DS menu behaviour will be removed, so I wanted to bring this up. I like having the floating DynTopo menu on my screen. Thanks.
