Hi. I’m not sure whether this is intended or not, but I’m having other tools other than the paint one (in this case, drag) painting a material on an object as I use it. Is that intended? Thanks.
That was it, thank you!
Hi. Can this feature be disabled for good? It keeps popping up, not just on the drag tool but on the others as well.
It’s disabled by default, so it means you somehow enabled it…
If you saved a tool preset make sure to save it while it’s disabled.
Otherwise don’t open the popup on the lower left, it automatically enables painting.
That was it! The bottom left pop-up. Thank you!
