Curve repeater taper
The new curve repeater is absolutely awesome!
Though noticed a bit of a bug, working on a curve that tapers at the end, closed the app without validating then reopened, the curve was still editable but tapered end had reset to standard start diameter.
Also happens when invalidated curve is saved and reloaded
Fixed on next release
That’s all fixed now in 1.74, thanks! The thing is now I don’t seem to be able to add/move points to the curve or move taper controls with Apple Pencil only finger will make adjustments, is this by design?
Argh yes, the bug occurs with the “stylus sculpt only” option, the logic has been reversed.
