Curve repeater moves the wrong way when editing points
Not sure how to describe this but I’m using a curve for this stitching. It’s supposed to be lined to the left. It’s hovering just slightly above the green string so I rotate the view to see the string sideways. (Can’t add another pic) While sideways, I move the points down to have it meet the string but when I go back to my original view (view pic), it’s now somehow shifted right. I don’t know how and whenever I try to fix it the same thing happens in whatever axis I’m in.
Pretty much if I hold my pencil on a point, it moves forward or backward from the camera view as if Normal is on (like with the Move tool).
Side view before I touched the points. It was all shifted neatly to the left hand side of the string, but when I moved it, OP pic is where it ended up.
Likely because of snap. Unsnap when you change views and it should stay on the same plane.
I ended up having to delete the curve and create a new one and it’s fine now. You were probably right with the snap setting. I maybe had it on when I created it and it messed things up. Could also be a bug, who knows. Either way, thank you!
Really wanted to say that the snap is not the reason. But as it turns out it is the reason. Was having the same issue. Thx
