Maybe i don’t understand whole curve align functionality but nie behave strangly for me. I would like behavior as in the picture below. Current pivot/gizmo of repeated object should follow the curve.
Check align off and edit the correct rotation of the element. In my case I create an sphere with a box and changed the pivot to the center of the sphere.
Please look at this
seems all object have pivot in the center even i moved gizmo to the center of sphere
The gizmo is not used for the curve alignment, only the node center is!
If you need custom pivot for the curve simply group your object, then you can movie this group freely with the gizmo (use “object” mode on the left, so that it doesn’t impact the children.
