Would love an add on upgrade … like conform tool or flowify
It’s not perfect, but you can position your stuff to sit on the surface of the head, make a layer, reproject with most of the options disabled, then fade the layer back. Often this introduces some grid artifacts, but a quick tap with the smooth brush can usually fix it.
Thanks for the work around…
It might be that masking could be the best option to get the same thing.
