Does the unit have to be meters? Can we choose between meters and millimeters on our own?
Unit = universal
When you decide 1 unit is 1 Meter then you have to use in other Apps when importing 1 Meter as your unit… for most apps nomad unit is equal 1mm…
First, I conducted repeated tests. When exporting FBX files from Nomad, 3ds Max converts Nomad’s meters to millimeters. However, for OBJ format, no conversion occurs and 1 meter directly becomes 1 millimeter. When importing into ZBrush, both FBX and OBJ formats treat 1 meter directly as 1 millimeter.
