THE PLATFORM: iPad
NOMAD APP VERSION: 2.9.22
1.This issue has persisted across several versions. When inserting a group containing multiple components, the first inserted instance works normally, but starting from the second insertion, only an empty group is inserted without the other objects being copied along with it. The root cause is that after inserting the first group, only the group itself remains as the active object, and all internal objects get lost unless the entire group is reselected.
