THE PLATFORM: iPad
NOMAD APP VERSION: 2.13(2)
When a model consists of two disconnected parts, or in other words, when the Trim brush selection does not cross over the model, a boolean error will pop up. This issue occurs with both the Trim and Split brushes.
Hi. I’ve seen this before. Maybe because it sees your object as one piece and not two separate after you trimmed? Last time I encountered this I split the pieces into separate parts and then the trim worked great. Hope this helps.
I found this was my mistake. The current UI color made me fail to notice that symmetry was turned on; turning symmetry off fixed it. The issue actually came from a model sent to me by someone else. I got the same prompt when trimming it, and I confirmed symmetry was not enabled, so I mistakenly thought it was a bug. It’s my error, and the problem lies with that model.
Could you send me the nom file?
Okay, I’ve sent it to you via Gmail.
我好像遇到过这个错误,后续我发现对面剪裁的模型是用AI做的?最后没解决,不了了之了,没想到其他模型也这样,我也想知道为什么会这样
