I used zbrush new in here.
Where can l set my brush focal shift?
There is no “focal shift” in Nomad, but the you can edit the brush fall-off curve within the stroke menu. Second icon along on the top right menu.
Beside the free editable curve, you can scale the alpha as well. Together there are plenty of options.
No focal shift in Nomad, but editing the falloff should give the same result.
Afaik, focal shift is simply a quick way to edit the curve by adding an offset to it.
(Negative focal shift being the same as moving the curve upwards, while positive focal shift will move it downward)
