Autofacegroup
I‘m not sure if i accidentally unchecked a function or if there is a new option somewhere but i cant seem to create an auto-facegroup for the fill-area when extracting a mask and i cant find how to do it anymore :sob:
THE PLATFORM: iPad
NOMAD APP VERSION: 2.5
Not sure I understand, the extract mask already use difference facegroup for the side/top/bottom.
I’m not sure what you meant sorry, but its not generating a new facegroup for me in the separation section! No matter what method i use :grimacing:
Maybe check the FG settings for hole filling in the misc menu.
Maybe check the tooltip, yes
Ah sorry i did it wrong for the hole fill it used it be on auto, but it still doesnt work for trim or the mask extraction as it did before the update.
Sorry for that on i picked the wrong check as i did the screenshot (it was on auto when i used holefill) but for trim split and extract it still doesnt work.
Did you check the tooltip? It should be on OFF if you always want new facegroup.
I’ll rename the widget.
The program ended up crashing :rofl: But yeah now it seems to work again!
