I am writing to report a critical bug in Nomad Sculpt for iPadOS v2.10
Bug description:
The app crashes immediately every time I try to export a file.
This happens even with a brand-new blank project: add a simple primitive sphere, then tap export, Nomad will shut down and exit right away.
Not only complex dental grillz models, but basic primitives cannot be exported.
Device information:
Device: iPad
iPadOS version: 26.6.2
Nomad Sculpt version: 2.10
What I have tried to troubleshoot:
Fully reboot iPad, close all background apps, only open Nomad.
Create totally new empty project, only one simple sphere for test.
Tried export STL and OBJ formats, both trigger crash.
Reinstall Nomad App, the bug still exists.
I saw many users posted the same crash issue in your forum after updating to 2.10
This bug completely blocks the export workflow. I rely on Nomad to sculpt custom dental grillz models and need to export STL for 3D printing.
Hope you can fix this bug in the next update.
Thank you for your work.
I’m experiencing the same issue on my iPad Pro running version 2.10.
I can’t export any STL files. I also can’t save any rendered PNGs, though I’m not sure if that’s related.
Latest Nomad version crashes immediately when clicking export of any file on my iPad Pro M5, even for brand‑new default sphere primitive.
Saving nomad project file works fine, only export function crashes.
But exactly the same Nomad version works perfectly for export on my iPad Air4 (A14 chip).
Other 3D app Forma3D can export STL without any problem on this M5 Pro, so my iPad hardware is healthy.
I have fully deleted and reinstalled Nomad, reset all nomad settings to default, turned off iCloud drive, restarted device, problem remains.
iPadOS version:【iPad Pro m5 27.0.1 】
Because export will crash instantly on this device, I cannot attach test mesh file.
Please check this M‑chip specific export crash bug.
Description:
When attempting to export any model (STL, OBJ, etc.), the app immediately minimizes to the background and freezes. The exported file is never created or saved to storage.
Saving the project normally as .nom works fine. Reinstalling the app with default settings did not fix the issue.
I don’t know when the update will be live, it’s up to Apple, not me.
That’s the annoying part of the AppStore.
Usually it’s fast but it can take up to 1-2 days.
The iPad Air M3, nomad 2.10 is experiencing the same issue, waiting for the delivery model… When will it be fixed and urgently updated in the App Store?
You can go through Apple’s bug expedited channel for review, as we are in a hurry to deliver the model files.
