Ambient occlusion
THE PLATFORM: iPad
NOMAD APP VERSION: 2.8
Whenever I turn on ambient occlusion, this line appears in the middle of the screen where one side has it enabled and the other doesn’t. I don’t know what’s happening, but it occurs in all the models I have saved.
I don’t think I’ll be able to fix this issue.
As far as I know it only occurs on the oldest iPad that Nomad supports.
Which version is it?
Yes, it is indeed a 7th-generation iPad. But I find it strange because it had never happened before. Maybe if I uninstall and reinstall it, it will fix it?
No it won’t fix it, and it will delete all your files.
I know the cause but I’m not sure I’ll be able to fix it as I cannot revert the changes (it’s outside my codebase, ANGLE).
But still I’ll see what i can do for next update. But the next update after that I will likely drop support for older iPad.
I’m marking the thread has solved as I know the root cause of the bug (even though for now there is no fix).
Thank you for your availability and attention.
Keep up the good work!
