Adjust brush size via shortcut keys
I’m a windows user that likes to use a macro pad that is programed to have similar functions for the many programs I use. In most drawing and 3d programs the shortcut for brush size increase and decrease are bracket keys ie: [ and ]. I would like to be able to adjust the brush size via shortcuts. Also it would be good to adjust the intensity of the brush via a shortcut.
Maybe a mini window that’s also activated by a key that could bring up brush size and intensity.
It’s already there, go check in the bindings menu.
I see it’s called tool radius. However, you just make it brackets by default. It’s the most common shortcut used on many programs.
Thanks
