Brush size hotkey on [ ] brackets
Hello!
Is it possible to add possibility to add hotkeys on brush size using brackets ?
As it works in photoshop, zbrush, 3d coat and other software.
Thank you
Coming from Zbrush/Blender I think I’m ok with the hotkey + drag for resize but would love it if the resize widget was centered on the pen tip (as opposed to the pen tip being at the edge of the circle, which is clever but less useful).
I’m not sure I understand the request, you can customize every shortcuts in the bindings menu.
As for center edit, the idea was that you could keep the old radius and only make small changes.
But I might change the behaviour, testing multiple options (videos).
Note: you can also change the radius with the 3-fingers vertical drag on the canvas.
What I like about center edit is that you keep your position on the model and can continue sculpting. At the moment, your cursor moves away when you scale the brush, slowing you down a tiny bit each time.
I mean, it would be nice to be able to assign hotkeys to increase and decrease brush size to different buttons.
As an example of a “bracket” increase by ] decrease by [ . And all this with a certain step. For example, each press size is + 5 or - 5. or any other customizable number.
In my experience this creates a more seamless process where you don’t have to stop and pay attention to the size of the brush. The hand adjusts it automatically.
Dude, Stephane just answered you already. You can edit the keys in the bindings menu.
The settings that Stephane showed work by holding one button, or by gestures. I’m talking about a completely different way to change the size of a brush, when you use 2 hotkeys (Increase\Decrease on each button) instead of 1 (Hold down the button and change the size with the movement of the pen)
I also don’t have this setting from the video)
live variable sizing is great and i’m very used to it in nomad, but the bracket keys to go up or down in like 5% increments is pretty handy in other painting related apps, I’d find that useful in nomad too.
My bad
It’s in the incoming release.
Wow thank you!!!
