About turntable mode in camera rotation
Hi there,
I want to ask something about the turntable vs trackball camera rotation mode, not the turntable display.
I want to ask why there’s a limit that prevent the camera to rotate (called orbiting or tumble in other software) beyond the Top or Buttom side? For example you start at Front side facing the camera right? Using touch, you draging down so that finally Top side is facing the camera. In other 3D software you can continue to drag down so that you can eventually see the Back side (everything is upside down). However this is not possible in Nomad, there’s a limit that prevents you from rotating further beyond Top side. I have to switch to trackball mode to remove this limit.
