1.91/1.92 In Gizmo, the back to origin button is now missing
Normally, there should be an option to return to the origin here, and now he’s disappeared.
Indeed
I’m sorry, does your response mean you are fixing it, or does it mean it was fixed?? Experiencing the same issue.
It generally means he is going to fix it. He may have already done so. You can always try the web demo and check if it’s working.
I’m pretty new to this app, so not sure how things go. I see the move origin on the Web demo, how does fixes work? Like in general, i know the developer is super busy, so just trying to see how it normally works on fixes.
There is a WebDemo - this is actually always the current version of the development.
In case of a bug - check if the bug has been reported - then check the WebDemo if the problem still exists there…
If everything is OK in the WebDemo, it means that the BUG has been fixed.
Then wait for the UPDATE in the APPSTORE…
thank you so much.
