Tube tool not drawing curve or showing settings
Hello I’m pretty new to nomad and I was following a tutorial that show me how to use the tube tool. I first click and drag and let go but then when I try to place a third point it starts rotating my camera. It does the same with the lathe. I’m not sure if this is a bug or a setting I have randomly on. I did reinstall the app and try to reset the tools but did not see a difference. The settings are also greyed out. I am using an Apple Pencil. I don’t show it on the video but I also did turn on b-spline turn off the fixed/snap
Thanks
Normal behaviour. You need to insert point on the already drawn line.
It seems like this wasn’t always the case, at least the tutorial I’m following doesn’t work like that, it is a huge downgrade
I’ll probably bring back the previous behaviour.
Same Problem today, very frustrating.
Same issue. Unable to add another segment.
Yes, same here - very frustratiing. It would be great to have this “old” behaviour back, please. I’m on Android btw… Thank you :slight_smile:
It’s been added back in the next release (1.91)
You can play with it in the webdemo now:
Thank you - tried it and it works great :grinning:
It works? Not to me… what did you do to make it work?
Like @mestela said, it works in the WebAssembly - apparently later in the next release. :smiley:
How do you do an insert point
