Transform tool - drag snap
Currently the transform tool requires you to click the current object, and drag it where you want it to snap.
It’d be useful if you drag somewhere else immediately, that the transform tool would immediately snap the object to that location. If this potentially conflicts with other operations, maybe this could work when the lock toggle is enabled in the bottom toolbar.
This has come up when I have an object at the origin for example, I’m zoomed in elsewhere, and I want to quickly snap that object to where I’m looking. Right now you can’t do this, you have to ‘see’ the object to drag it in, which can break your flow a little.
Hopefully the attached video makes this request clear!
