I am trying to sculpt a king’s mantle.
I used a plain and a combination of the drag, pinch, crease and smooth tools.
But the results are horrible and awful.
I could not wrap the top around the “neck” and the rest look the worst.
Anyone has ideas/ tutorials on how to sculpt cloth, please?
Thanks in advance.
This is What I want to achieve:
I’m still a beginner, so there might be better advice around here.
- I would approach this by starting from the top, getting that main “fur” piece right.
- When that’s done, I’d create a tube to create the top of the “cape”. I’d first make sure that it goes around and snaps to the “fur”.
- I’d then mask the top, revert the mask and use the move tool to drag the cape (tube) to the bottom, while voxel remeshing to create that volume.
- Keep moving it downwards until you have what looks like a cape.
- When that’s done, add some creases and smooth them out to create the details.
Maybe this video will help you:
Thanks @MindGlowing for the steps. I will try to apply and see the results
Wow… Thank you very much @Holger_Schoenischka. Your tutorials are legendary. I can’t believe how you achieve results like this.
Thanks a million.
Definitely just follow @Holger_Schoenischka 's tutorial, way better than my shitty explanation
@MindGlowing Oh No… I really appreciate the time you took to write me the steps. Much appreciated
