Thicken thin parts toggle on or off across an entire project of make the default to off
i see thick thin parts has changed to a slider with as far as i can see unless im mistaken no way to turn it off from defaulting to 50%
its on by default for objects which is problematic and time consuming have to slide each time i voxel rems as it ruins sharp edges. I would like to see either a toggle or better still just as 0 by default and then it can be used if needed rather than charge if you don’t need it.
Ive just found its been quite disruptive to my workflow. if i forget to slide it to zero, go to print and wonder why edges are ruined or parts don’t fit correctly.
It didn’t “become” a slider, it wasn’t exposed previously, it’s a new option.
As for default, the voxel settings are always tied to the object, it’s not global.
Sharp edges with voxel remeshing is already a bad fit but I’ll see if I can make the thin parts work better, it’s there for a reason…
If I can’t I might make the option “sticky” so that it default to the latest used value or something similar.
Defaulting to 0 would be way less destructive, especially since a missed setting only shows up after the remesh has already chewed up the sharp bits.
