THE PLATFORM: Windows 11
NOMAD APP VERSION: 2.9.32
Yesterday, I had the 2.10 update (from 2.9.32), but the application was stuck on the auto-save dialog asking for a file name. Currently, I do lot of small tests on throw-away models, so I don’t save regularly. I deactivated the auto-save. An option to auto-save only when the model is saved first would be nice, but, sorry, that’s off-topic.
Anyway, the update was stuck because of this modal window and failed.
Today, same thing: Nomad indicated it could update to 2.11 (so soon? Do you use semantic version numbers?). I agreed to do the update, it downloaded it, asked to proceed with the update itself. Then it warned it couldn’t close the app because there is unsaved work.
So I went to the application, and clicked “Don’t save” in the dialog. The application froze, and I had to kill it after a while. The update went away with the main window… I am not sure if I can install the just downloaded install file, and how.
[Update] I found the Check for updates button in the home dialog, and now it is going to update to 2.12.1? Wow, crazy pace of updates! ![]()
This latest update went well. It didn’t restarted by itself, but after I re-launched it, it worked.
