Hello, new to nomad. I’ve created a can of spray paint, and I’m trying to find a way to put a sticker or label of sorts that I’ve created in procreate onto the main shape of the can. It there a way to have my image wrap around a cylinder?
Nope, no wrap. Nomad allows projection, like projecting the logo on you can with a video Beamer. You’ll have distortions on sides.
Sorry I know this might be a bit late for you……but do you mean like this?
I found a way of wrapping images around as textures in Nomad. This was mostly thanks to a youtuber called procreateFX who showed something similar in a video. I believe he is also a member and helpful poster here named Holger_Schoenischka.
Thanks @Brooke1 for sharing that, will be checking that one out.
Wow @Brooke1 so kind of you to prepare that and give such a good step-by-step process of what to do. Much appreciated.
Unless the label needs a thickness couldn’t you just UV unwrap the original cylinder as well and just add the texture there?
If you unwrap the UV of a cylinder, then you will receive an unusable UV for stickers.
