Bug reports split line crashed every time I tried to cut a bevel on a low poly box. Tried it 10 times and each with the same result to make sure
Could you show a screenshot of what you are doing?
I have had the same problem but it only happened after I was able to use the split tool successfully for a while. Did you find out how to fix it yet or have gotten a reply from the devs?
