Shape masks aligned to surface
Hi,
Not sure if it was mentioned before or if it is already possible.
I would like to use a rectangle or circular mask in 3D, aligning to the surface. Currently the mask works in screen space. Is it possible to have it work in object space? For example if there is a cube viewed from a non- perpendicular angle and I draw a rectangle mask, it will be perfectly aligned with the cube.
