Pen pressure on Surface Pro 6 WIndows 11 not working
I am having issues getting pen pressure to work on my Surface pro. I am able to get it to work with ZB not using wintab. Any tips to get it to work?
Nomad Ver 2.9.13
What’s the wintab value in the Nomad top left menu?
I have tried auto, no, and yes. Its all the same
I’m on 2.9.27 and the pen pressure on the surface pro 6 still does not work. I have the Surface updated. When I select Yes, no or auto there is no difference in pressure.
Using 2.9.29 and still unable to use the pen pressure on my Surface pro 6. I have verified that windows ink works and the pen pressure works in other programs
I don’t know but I won’t do anything.
I already support wintab and non wintab method. If it doesn’t work after that I have no idea, look into your tablet settings.
That’s too bad. The pen pressure works on Zbrush, Krita, and Photoshop without doing anything.
Windows Ink can interfere with Wintab drivers, including loss of pen pressure.
In my own experiences with Win Ink, it sucks.
Microsoft has a bad habit of breaking things so that you only use their solutions.
It works with the aforementioned programs. Not sure why it wont work with nomad now when it worked in the past.
You: I’m thirsty
Us: Drink some water
You: But I wasn’t thirsty before
The moral, you can’t help everyone
Check that you did not disable pressure in the stroke menu?
Or try disabling “use extra input samples” in gesture menu.
With win tab set to no. I turned off the global pen pressure and it worked. Turn it back on and reset the radius and intensity and it seems to have come back.
Thanks for the help.
