Panel Loops for Facegroups
Like in this Video:
Yes, this can be really usefull! I saw extracting from mask already has borders options, I don’t know if that can be applied with out extracting at all.
Isn’t it already there (facegroup menu)?
Hello Stephomi,
I believe what Holger means (please correct me if I am wrong) is the abbility to make panel loops all at once. As you can see in B, I can create panel loops perfectly when facegroups are not touching each other; or when they do they are concidered as one. But when I like to have the entire sphere (A) create the parts with bevels from all facegroups I get a result like in C .. I’ve hidden two parts so you can see the underlying structure; there are no separate panels. And it would indeed be great if we have that possibility too.
In case it is already there, which steps do we need to take? I can’t find it in de facegroup / mask extract menu.
Elfriede
Nomad Sculpt 2.13
It works exactly like B, but you didn’t show your extract settings.
Did you choose “shell”?
Hello Stephomi,
I did use shell in both cases (see screenshots). But I did notice an extra setting in your screenshot : GAP (under height) which I don’t have yet. Maybe that’s the reason? I checked the demo version on my iPad (webbrowser) to try it out but it’s not yet available there either.
Elfriede
PS : I love working in Nomad Sculpt; thank you for all you do!
PS : testing on my 11" iPad Pro, with M4 and 1Tb
I apologise, my mistake .. I just noticed I was looking under the mask settings earlier on, while you clearly mentioned to look into the Facegroup settings; which is also shown in your screenshot. Wow! We do have panel loops :smiling_face_with_sunglasses: .. time to play.
Thank you!
@Elfriede it’s posible to make a polyloops without extracting?? I thought that was what @Holger_Schoenischka was tryied to show in the video.
There is a small bug for this panel loop thing (some edge issues) - but it’s fixed for next update said Stephomi.
I guess no - it only works with extract.
But I guess Zbrush feature is also a extract thing.
Actually in Zbrush the panel, edge and group loops functions are aplied over the same geometry without extracting by default, I think this can be a really powerfull implementation.
I don’t think so. It works like shown in de video Holger posted. As for Zbrush, it has been many years ago I haven’t worked with it and I can’t remember if what you look for was possible their.
I was testing it on Zbrush today, and it does create geometry in the same subtool you can extract them if you like by PolyGroups.
@Gustavo : Thank you for testing it in ZBrush and adding a picture. That helps me better understand. If Nomad can add loops around the polygroups with the option to extract or not, it would be a lovely bonus for sure.
I have been playing around with it and find the update concerning the target within the Facegroup tab (web demo) way better .. version 2.13 gives a choice between active and all. In the new one you can choose all or deselect / select your colour patches .. no need to hide facegroups first. It’s easier .. kudos to Stephomi.
Would be nice to see you also on Nomad Sculpt Discord - that’s the place to be, when it’s about Nomad. :smirking_face: Greetings Holger
Thanks Holger! I’ll give it a go either today, tomorrow or the latest this weekend.
Hello Holger .. I tried to open a Discord account today but I got a blank page. I only use my iPad Pro 11" M4 (in case this info matters?) to go online. I used the link on the Nomad webpage. Do I need to go to Discord’s webpage and search for Nomad Sculpt? Once I know the first step I can ask my brother to help me further, but that might take a few days before he has the time to do so.
Kindly .. Elfriede
Hello,
as far as I remember on IPad you have to install discord APP
Then the invite link should work. (Invite link doesn’t work if you only use discord website - don’t know why…)
After this you could use the discord website …
I can only say discord is the best place for nomad - Stephomi is there most of the time - there are also Beta Test channels etc.
Greetings Holger
Thank you Holger. I’ll look into it.
Kindly .. Elfriede
On iPad, the App Store Discord app is usually the least painful route. Install it, sign in or create the account inside the app, then use the + / Add Server button and choose Join Server, pasting the Nomad invite link there. You shouldn’t need to search for “Nomad Sculpt” manually. If the invite still opens a blank browser page, copy the URL and paste it into the app’s Join Server field instead.
