Nomad Change Log
2.9
• New tools
  • Elastic and Polish brushes
  • Arrange: spread objects along a line, circle or sphere
  • VDM brushes: capture a VDM from your sculpt, sculpt a new one, fix existing ones
  • Text primitive with Google Fonts
  • Link: live sync with Blender, ZBrush (GoZ) and other Nomad devices
• Sculpting
  • Stroke trail, random intensity and color
  • Hold a stroke to snap it to a shape
  • Separate area and falloff normal filters
  • Tiled symmetry, symmetry from the pivot
  • Fix alpha: flip, rotate, clean borders
  • Nudge fold, Smooth keeps borders, Trim keeps topology
• Curves and primitives
  • Edit curves with the Move tool
  • Curves: IK, sharpness, bevel and warp
  • Spiral presets: rope, braid, ribbon, strands
  • New cap fills and rounded caps
  • Surface repeater: scatter copies on faces or edges
• Mask and selection
  • Gizmo pivot reset: mask, center, top, bottom
  • Improved Lattice: point selection, soft radius, rigidity
  • Mask grow, shrink, border and cavity
  • Face groups from UVs, normals, parts or mask
  • Measure: shortest path and cross-section
• Topology
  • New Autoremesher and UV unwrap
  • Bake from multires
  • Voxel remesh: edge length, thicken thin parts
  • Decimate: preserve borders and painting, uniform faces
  • Split by parts, groups or layers
  • Clean overlaps, weld radius for positions and UVs
  • Extract: bevel, gap and wall profile
  • Trim, split and project on several objects, with masking
  • Better hole filling
  • DynTopo keeps UVs
• Painting and rendering
  • 25 layer blend modes
  • Texture curves and material picker
  • Volumetric fog
  • Poly Haven environments and textures
  • Radial and sky gradient backgrounds
  • Depth of field aperture mode, better SSAO, render with transparency
• History and files
  • Save the history with your project and replay it
  • Export with embedded assets and history
  • Import: merge duplicate positions and UVs
  • STL for scenes over 50M triangles
• Interface and input
  • Customize the interface: colors, glass, accents
  • Reorder the top menus, HSB and RGB color sliders
  • Snap to grid and to points
  • Reorder cameras and lights
  • Gamepad, SpaceMouse on Mac, trackpad gestures
  • Apple Pencil: more precise on lift, tap while hovering
