1.60
ios: allow more memory usage for M1 iPad Pro
ios: improve drag n drop support (object file only)
primitive: fix radius icon for cylinder and tube being disabled (if lathe tool was used)
mask: fix accumulate behaviour when it is disabled
insert: allow sculpting on cloned object (if the base object is not a primitive)
project: add “Export selection only” to internal “Save as”
light: modal popup for editing parameters
layer: add extract feature
tube: fix radius being clamped (slider only)
