explain the negative and positive extract process
Adjust the extract thickness into the negative or positive numbers (blue arrows).
Or adjust it and then tap the ± button so that it says -, +, or ± (pink arrow).
“+” Positive will add material on the outside of the mask (stick out)
“-“ Negative will subtract material on the inside of the mask (push in)
“±“ Both will add material on the outside and the inside the mask (both stick out and push in)
