Arabic Language Display Issue – Text Appears Reversed
I noticed that when typing in Arabic on the forum, the text appears reversed and is displayed from left to right instead of the correct right-to-left direction. This makes it very difficult to read or write in Arabic properly.
It would be great if you could look into supporting proper RTL (right-to-left) text alignment for Arabic.
هذا اختبار.
This is a test.
It should work better.
Hi, thank you for adding Arabic language support. The text direction is now correct (right to left), but the Arabic letters are still not connected properly — each letter appears separate instead of joined as they should be in Arabic script.
I hope this can be fixed
في جمعة، 6 يونيو، 2025 في 4:01 م، كتب Stéphane Ginier via Nomad Sculpt <notifications@nomadsculpt.discoursemail.com>:
Test the demo instead nomad - WebAssembly
It’s more up to date.
