Hello, friends.
I need help.
I have several alpha files in my Nomad on my iPad.
But I don’t understand how I can access the internal folder of alpha files?
I forgot how these alpha files were imported into Nomad, and now I can’t find the folder with them in the Files app.
I want to get copies of all these alpha files in an external folder for organization and sorting.
Can you help me with this?
If there is no way to access the folder, then I would like to delete these files and I don’t understand how to do this either.
The context menu when long pressing on an alpha channel element is disabled.
The Kenny patters have no folder. Not possible to delete - hide them by collapsing the folder.
Thanks for the quick response!
It’s a pity that they can’t at least be removed, they seem great, but they a bit out of place in this format.
You can’t delete base assets in Nomad.
But you can collapse the folder and it will stays that way.
Not being able to delete them shouldn’t be an issue, it’s the overall asset folder hierarchy UX that’s not great.
It could change one day, maybe something similar to the toolbox folder selector.
Thanks for your answer. It’s good that the folders remain collapsed. Your approach to working with UI in Nomad is impressive, I’m sure you will find the best solution when you tackle this task.
