After new update: Render Panel Behaviour is Broken
With the recent update, after a user renders, the resulting screen, when touched in any way, shows the Apple Notes drawing tools.
Moreover, accidentally touching the screen in any way triggers the pen tool, and causes any transparency in the image to become white.
The long press → drag out to other software feature is completely broken now due to this, and requires many extra steps to move renders to other software such as procreate or toonsquid.
Doesn’t sound like much, but it’s turned 1 step in to 3 (copy, paste, confirm paste- or save to file, import file, delete bloat files) which adds a lot to certain workflows. Not including when the user accidentally touches the screen and then needs to hit the ‘undo’ button else all transparencies become white, which is another step.
As an aside, I’ve also noticed a few stability and performance issues since the update. A bit laggy, and have had a couple crashes, which never happens on this awesome software! I’m running on a 2024 iPad Pro.
Thank you so much for your hard work and for reading my note.
Afaik most people simply use the share button (top right) after the render export, so it doesn’t change much as it’s still there.
Nomad is objectively faster on the latest update, I don’t trust this “a bit laggy” thing unless you maxed out the postprocess (in that case, I removed the “half resolution” option that’s simply too low quality, if you need speed you disable postprocess)
And “couple crashes” is not helpful at all, states explicitly what actually caused the crash.
And you didn’t mention which version you are in (2.4? 2.3.34?)
2.4
Crashed when rendering yesterday, fairly basic scene- then after reboot crashed again soon after freezing in (non post process) editing mode.
Anecdotal of course just feels less responsive than before the update. Same postprocess settings, not maxxed out.
The render workflow is really clunky with those drawing tools always triggering accidentally.
I didn’t change anything postprocess wise. Maybe reduce the resolution, it’s the most important setting for performance.
