Would a function for the 2nd FINGER be conceivable for the Trim / Split tool at some point ?
In Procreate you can use the 2nd finger to snap.
In the polygonal tool this would be very practical to snap angles or straight lines.
Also for the Line Tool it would be very practical if it would snap with the 2nd finger e.g. 15 degree grid…
(I know that you can also set the angle in the menu, but this is rather inconvenient, because the angles can change constantly).
Snap as in the trim/split area is printed down onto the area you placed it over from a particular vantage point? Am i interpreting this EOA idea correctly?
Sorry but I don’t understand the meaning of the question, I need to translate and the translation doesn’t make sense
But it doesn’t matter, because Stephan won’t install it, because I don’t think the 2nd finger can be used that way.
