2.12 (8) Has the invert function for Alpha images been removed?
THE PLATFORM: iPad
NOMAD APP VERSION: 2.12
The invert option for Alpha textures is now missing. In many cases, Alpha images need to be inverted to meet usage requirements. When sculpting directly with an Alpha, the brush’s built-in invert function can be used. However, there are scenarios where we draw with the Mask brush. Mask only supports global inversion and cannot modify individual Alphas, so this feature is indispensable.
I believe keeping this function in its original location would be a good choice, as many users are accustomed to it. We could even add an invert button to the long-press edit menu for easier operation and adjustments.
Click “fix” in the asset collection when you select your alpha.
Wow! There are so many changes in this update. I would never have discovered that hidden Alpha feature if you hadn’t mentioned it.:laughing:
The fix option does is grayed out for the Kenney collection of alphas. Why is that?
Only supports modifying custom Alpha images.
