Tube to Curve - help - how to align objects in multi radii mode
Not sure if it behaves always like this, because I thought Curve becomes same as Tube so that radius / twist etc. is also converted to the curve. At the moment it looks like this, so 1 big object and all the other objects are small. So how to make the red object follow the curve - and keep size fit to curve ? Do I have to adjust every node by hand - 5-6 nodes are doable but what about 50-100 nodes ? (Red object is extracted from tube and the goal is that the red object follows the tube in size and twist…) Only with multi radii it behaves like this.
Project 75.nom (536.0 KB)
