Is there any way to set there the orientation on an imported stl file.
A friend used his iPhone to scan his head. It was then sent to Nomad and it needs to be adjusted. For example. It looks like it’s laying on its side at an angle. So in on the orientation cube where it says TOP you actually see the Left Side of his head. I’d like to move it facing the right way. Is this possible?
You can use the Gizmo tool in the right side menu.
Awesome.
That did the trick.
Thank You So Much!
