Low fps after update
THE PLATFORM: Android
NOMAD APP VERSION: 2.11
DEVICE: Mi Pad 7
I noticed a bug after the update. When I switch to full-screen mode, the FPS in the app drops to 20–30. If I open another app on top of it or minimize the Nomad window, the FPS returns to normal.
If you hide the gui, is it better (4 fingers tap or minify option in the about menu)
I found a similar issue where you recommended hiding the UI. This improved the FPS by about 10, but the FPS is still much higher when Nomad is minimized.
Ok found the issue, will be fixed shortly.
我也遇上了这种问题,感谢你的临时解决方法(开一个额外的窗口)
